Control Arm Rebuild
I am going to rebuild my control arms. This seems to be possible, but I have only found 2 sources for ball joint kits, one fairly expensive, and one that doesn't actually include the ball joints. I want to rebuild the ball joints and replace the bushings. Any advice as to what to expect, or especially parts/suppliers, would be appreciated.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-22-2004, 05:00 PM
TopsailBeach's Avatar
No problem. Check this out---http://clarks-garage.com/. Lots of advice and links. Also, do a search for 944 ball joints on an internet search engine for even more info. Just did mine. It's worth the time and cost.
A J Burns
'07 Guards Red Carerra 4S 911 Coupe w/Aerokit
'86 Iris Blue Carerra 911 Coupe (given to my son)
'63 Morgan Tiger Cub w/original Atomic 4
Old 10-22-2004, 07:32 PM
Clark's garage has the procedure I originally posted on my 951 RacerX website. The kit I got from Sloan is the best out there and costs less than a single rebuilt arm for TWO! How can you beat that? And it uses brass cups instead of the stupid nylon ones that came stock and that others sell in their rebuild kits. Once you install this kit, you'll never have to worry about your A-arms again!
Old 10-23-2004, 09:01 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
I'm such a slacker... yet another thing that's been on my list for months.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 10-23-2004, 10:27 PM
Contact travis at rennbay.com, not only good prices, but if you get stuck, you can call him and he will walk you through it....excellent customer service.
Doc Wilen
86 951
Old 10-24-2004, 04:25 PM
I'll be going the Rennbay route. Danno, I'll be making good use of your procedure, thanks for taking the time to do that write-up. I'll post my results, and of course any questions/problems with me control arm experience.
Old 10-25-2004, 01:55 PM
Travis also has a good write up with pictures on the rennbay site of the procedure.
Old 10-25-2004, 02:48 PM
