scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
question about the starter
is it possible or likely that the teeth on the gear comming from the starter break or grind off before the starter dies?
reason im asking is that whenever i start my car i get a god awful noise from the starter that sounds like grinding with slipping.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-01-2004, 11:15 AM
fast924S's Avatar
Send a message via AIM to fast924S
It can happen but its more likely the flywheel ring gear teeth, Pull the starter and check both
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-01-2004, 03:17 PM
well if its the flywheel ring gear teeth does that mean new flywheel?
Old 11-01-2004, 03:23 PM
fast924S's Avatar
No, I think but Im not sure that you can remove the gear and replace it, But again Im not sure. But check before you do anything
Old 11-01-2004, 03:27 PM
