Motor question
Just bought an 85 944, it has been sitting for 4 years. Did a compression check and had 175-180 on three cylinders and 120 on one, squirted oil in cylinder and it did not change, am I sunk? Any other ideas? I guess I could do a leak down check, but it seems as if I have a valve issue? Any assistance or advice would be appreciated.
Thanks,
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 11-05-2004, 03:45 AM
Parrothead member
VINMAN's Avatar
Sounds like a valve problem. check it a few times after turning the engine over, see if you get different readings.
Vinny
Old 11-05-2004, 05:31 AM
ae1969's Avatar
Send a message via ICQ to ae1969
You should do a leak down at this point.....
It could still be losing compression through the rings or as suggested... intake, exhaust valves...... or the head gasket.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-05-2004, 07:14 AM
fast924S's Avatar
Send a message via AIM to fast924S
Im with ae1969, Do a leak down test and see what happens
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-05-2004, 02:35 PM
Also, after sitting for 4yrs, the lifters are bone dry. The valves in the cylinder with the low compression might have a valve that is not fully seating, basically what they said!!!!
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 11-05-2004, 03:40 PM
