Motor question
Just bought an 85 944, it has been sitting for 4 years. Did a compression check and had 175-180 on three cylinders and 120 on one, squirted oil in cylinder and it did not change, am I sunk? Any other ideas? I guess I could do a leak down check, but it seems as if I have a valve issue? Any assistance or advice would be appreciated.
Thanks,
2011 Chevy Silverado (The Hauler) 1984 911 Carrera summer daily driver |
Parrothead member
Sounds like a valve problem. check it a few times after turning the engine over, see if you get different readings.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
You should do a leak down at this point.....
It could still be losing compression through the rings or as suggested... intake, exhaust valves...... or the head gasket.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Im with ae1969, Do a leak down test and see what happens
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
Also, after sitting for 4yrs, the lifters are bone dry. The valves in the cylinder with the low compression might have a valve that is not fully seating, basically what they said!!!!
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
