e-break troubles
I'm trying to swap out my driver's side trailing arm, but I'm having trouble removing my e-brake cable. The pin that attaches the cable to the actuating arm (or whatever that pitce is caled) is frozen. I cannot get it apart to remove the cable from the arm. Any ideas on what to do?
My current course of action will be to replace both the trailing arm and the cable, but I'd rather be able to take the cable out of the arm I'm pulling.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 11-07-2004, 04:31 AM
jim302's Avatar
If you have the time, Soak it overnight in DOT 3.
I am not exactly sure of your situation (never done that job), but dot 3 brake fluid does wonders for eating corosion and paint.
Black 944 NA
Old 11-07-2004, 05:53 PM
