scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Unhappy Ever wonder what happens when you go over a tires speed rating?
this didnt happen on the p-car but it could if you get el-cheap-o tires. and the tire still holds air, i stopped before it poped.
Brand and type: Multi-mile Talon 2000 + 130mph =
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-05-2004, 11:38 AM
TCMdocs944's Avatar
Looks like overinflation or a dry tire.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 11-05-2004, 01:54 PM
Yeah..A case of "dry rot" and over inflated. No way on even a cheap fresh tire could 35psi do that, especially on a radial...
Bob S. former owner of a 1984 silver 944
Old 11-05-2004, 04:03 PM
I think he's saying excessive (but fun) speed caused the tire to fail, not too much PSI. Centrifugal force, or the tire hitting the road too hard could maybe do that, couldn't it?
Red 1967 Saab "96", needs help
Blue 2002 Pathfinder SE
1991 240SX-SE, auto, trans was shot - junked it
Old 11-05-2004, 04:56 PM
the tires are checked every 2 days and they were at the right PSI. its just these tires werent meant to go through what i put them through on a daily basis. main reason ive been so hard on them is i wanted to have fun with them while i could use them, i have a 5 lug swap sitting in my garage right now, so i thought id get my moneys worth of fun out of them.
Old 11-05-2004, 06:10 PM
Send a message via AIM to 944 Pylot
Wow, any control issues after that happened at 130mph?
Also, it had to take forever to get up to 130 in a 924S. I think the published maximum speed of a 944 is 130. It would take me forever to get up that speed with how tall 5th gear is. I know the 924 is slightly more aerodynamic, but it can't make that much of a difference, can it?
Black '83 944, K&N, round throttle cam, Magnecor wires, 17" 993 C2 wheels, sound
Old 11-07-2004, 02:23 PM
it didnt happen in the 924S, it happened in a 2nd gen rx7 and no it doesnt take that long to get up to that speed in either car, more in the rx7 though.
i have personally reached over 140 in my 924S on a flat sufface in FL. ,y car isnt the regular 924, it has the 944 engine and drivetrain but its lighter and more aerodynamic.
edit: no there werent any control issues. i noticed the car wasnt right, it was vibrating more and immediately slowed down to 65mph when it started vibrating a LOT more. the only time i had felt it vibrate like that is when i had the same wheel fly off the car at 70mph from the retarded PO not putting the lug nuts on all the way when i was driving it home. after about a mile of it vibrating really bad i heard something hitting my fender and pulled over to a stop.
Old 11-07-2004, 02:59 PM
Had similar thing happen with Firestone Dayton- really El-Cheapo tyres do not pay off. My problem was not speed but poor tyre manufacture where rubber separated from casings on 3 of these tyres at different times. Thought it was shocks or allignment on my Opel and had these checked, but have had no problems since with Brigestone.
Old 11-08-2004, 04:47 AM
yeah i remember firestone having the problem of the tread separating. the first thing my cousin asked when i told him what happened was if it was a firestone tire.
Old 11-08-2004, 08:42 AM
I went over 130 in mine last night (fun)scary. I was running with and Acura RSX-S and a BMW 328is and kept with both of them. It is amazing what the 944 feels like a 130+ not overly responsive and not shaky at all. I love it.
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 11-08-2004, 03:15 PM
i acctually like mine going faster because between 60-80 it has a bad vibration, but the faster i go the smoother it gets
Old 11-08-2004, 03:42 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Originally posted by scheistermeiste
That really doesn't look like over-speed damage. Over-speeding a tire tends to fly apart from the side-wall, not in the middle of the tread. Speed may not have helped, but I think that tire has some other issues, too.
Also, how did you get 130mph in an S4?
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 11-08-2004, 05:08 PM
well it was 130mph on a few turns, and hod i do it in an S4? down hill baby!
Old 11-08-2004, 06:24 PM
