-   -   Where is my paint code? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/192447-where-my-paint-code.html)
Clowd 11-15-2004 06:31 PM
I thought it was in the spare tire compartment.. but it isn't. I need to repair some damage on the front drivers side.. the plastic peice, I'm not sure what the proper name for it is.
952 11-15-2004 07:00 PM
Should be on the inside of the back panel just above the spare tyre area behind the carpet... unless its different for you LHD guys.
Clowd 11-15-2004 08:51 PM
Nope, it's not there..
952 11-15-2004 10:50 PM
Then its either not there on LHD 944's or its been rear ended and the code panel not put back on. :D
gtroth 11-16-2004 04:11 PM
I just saw that on mine somewhere (not near the spare tire). Sticker inside driver's door jam maybe? Sticker under hood? Just a guess.
WaA420 11-16-2004 04:28 PM
944 paint code
If you still have your owners manual packet look in the warranty and maintenance book. Right inside the front cover is the white label that 952 is talking about and there is your paint code. Under the hood you may find a label that tells you what the color is called but no paint code. If the white label in the tire well is gone these are your choices.
952 11-16-2004 04:31 PM
If you post a pic... we can tell you it!
Clowd 11-16-2004 06:36 PM
http://www.ueak.net/chayes/both_cars_003.jpg
Clowd 11-17-2004 10:22 AM
Anybody?
ae1969 11-17-2004 10:26 AM
It kinda looks like marachismo red............ but was that an option that year?
Has it been repainted? same color in the engine bay?
Clowd 11-17-2004 10:46 AM
Engine bay is same color.. Maybe like, half a shade darker. I'm not sure if it's been repainted..
According to clark's garage, that was an option in 87...
Maraschino Red Metallic L Y3V
ae1969 11-17-2004 11:09 AM
http://forums.rennlist.com/rennforum...id=11317&stc=1
They sure look alot alike........
Clowd 11-17-2004 11:44 AM
Don't have a rennlist account, I'll make one.
Rmills944 11-17-2004 12:23 PM
On my 84, it says under the hood toward the driver's side of the firewall. It has the name and number for the paint. LM3V Rubenrot metallic.
SOmewhere on Rennlist there was a chart showing what colors were made each year.
gtroth 11-21-2004 04:04 PM
Sticker is under hood, just to the right of the fuse/relay box.
