Recent Purchase
I recently purchased a 86 944 with 76k miles on it. After driving this for the past 2 days, noticed a couple of things.
the sunroof, doesnt close completely and on high speeds opens up slightly letting air inside. my steering is a little tight. the interior light does not work. I just wanted to get an idea how much these things are going to cost me to get it fixed. thanks |
...cough
Parting out an 83 with black interior and two red racing seats |
Ornery Bastard
Clark's Garage has a procedure for checking the sunroof. It's a fairly simple repair, or at least it was for me. Took about 45 minutes for me to replace both gears, set the lifting arms, and get the microswitches into the right place on my 1987 924S that I had before the 944 I have now. Do _NOT_ continue to drive the car without fixing the sunroof's rear latches or you _will_ end up playing "freeway frisbee" with that roof panel. The front latch is meant to keep the panel vertically in place, and it can slide backwards off the front latch even if it's latched in the front.
What do you mean by "the steering is tight"? The 944 has much heavier steering than a family car, yes, but it's not over-tight. If you've never driven a car like this before then it's going to feel over-heavy to you. If you're used to Hondas or Fords then you're used to steering that's lighter. As for the interior light, have you checked the bulb, the fuses, and the connections? Very simple and easy to check. Should have been the first things you did. Aaron EDIT: Early_944, you're in round town eh? Former Ohio guy myself. Have a good friend in Chillicothe, still miss the area.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 11-18-2004 at 08:41 PM.. |
I assume you turned the key to position 1 & pressed the sunroof button to "lock" it in place? What you describe is as if it is in the "unlocked" state, that is, ready to be removed.
Jeff 78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
i have been getting home late the past 2 days, its really bad after buying your car you cannot get to see it during daylight.
I checked out the clark's garage and it looks like i may not be closing it properly. I will check it out saturday morning. The steering, is yes heavy. I have not driven a porsche before,(but have driven other german cars). This could be a little getting used to i guess. Thanks guys. |
Your sunroof issue sounds like your microswitches for the unit are toast. Typically the teeth on the gears will strip, causing the problem you describe.
-Zoltan.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Z-Man, How can this be fixed? is this a do-it-yourself or should i have to take it to the technician?
(more importantly how much is this going to cost?!) |
You'll need to buy some new parts (I belive Pelican has most of what you need), but you should be able to repair it yourself.
Check out clarks-garage the web, or a do a search here and on Rennlist's 944 forums - there are detailed instructions for doing this. -Z.
least common denominator
Your car should have come with power steering standard however our cars are notorious for P/S leaks. Check to see if there is any fluid in the reservoir.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Ornery Bastard
Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
