Basic Tools to have?
Ok guys, I figured I’d find out what the basics for tools to have around are for working on cars. My dad gets annoyed when I use his tools (mostly because I don’t put them back, oh well my fault) So I’m going to pick up my own set so I can leave the old man alone.
I obviously need the Metric Sockets and wrenches as well as screwdrivers. All that is the easy stuff. What else should be part of every mechanics tool set? Maybe tools Specifically for this car, such as a datalogger or something that would be just amazing to have? (Christmas gifts ![]() Anyway, post away what you think would be good things to have around.
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Just start with some sort of basic set. The most-used tool kit I have is a little set of metrics in a nylon case I bought at Pep Boys - it seems to have almost everything I need to work on any of my Porsches. For large jobs, I use a Craftsman starter kit bought on sale at Sears for about $100. All the other stuff (extensions, oil filter wrench, certain large sockets, multimeter), I added as needed.
Emanuel Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers |
Whatever you get, you'll need-
3/8 drive metric sockets- short and deep 3/8 ratchets 3/8 extensions screw drivers metric hex bits (beats the stuffings out of allen typ wrenches) Then add stuff as you need it like 1/2 drive stuff, breaker bars and any specialized stuff you might run into.
86 951- again on the road, but needing some more TLC 82 931- again among the rolling "If yer paint aint chipped, you aint passin nobody." |
torqe wrench breaker bar, extestions. if you can afford it i HIGHLY recommend air tools. im working on a 17 year old rx7 now and air tools have saved me. also i recommend MAC or craftsman because i have broken so many tools trying to get out rust bolts. also vice grip tools. but i cant stress enough to get tools with a warranty!
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
Ya, I was going to get craftsman, mostly because of the warrenty but it also comes in a set. I have a cheap ass toque bar, that im not ever sure how it works at this point. Air tools would be cool but that may be a little bit out of reach.
Wire wheel, vice, C-clamps, torque wrench, 10" crescent wrench, Channel Locks, needle nose pliers, jack and stands (Sears has a floor jack and 2 stands that I picked up for $25, and the jack and a piece of 2x4 fit under the car), deep well sockets, and the triple squares for CV joints. Oh, and lots of PB Blaster.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
I have everything there, execpt the channel locks. triple squares and the crecent wrench.
PB blaster is indeed the greatest stuff ever created.
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto Last edited by seaboltman; 11-14-2004 at 11:25 AM.. |
good set of gear pullers come in handy
1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten. |
meister member
triple squares are a must have. Don't try to use allens for those or your will strip them out. My advise is to get a basic set and add on as you need to. The way to justify the tools is just get a quote from a local shop on how much it costs to do a job. Say to your self "ouchy" them go buy your tools knowing your saving a boat load of cash. For instance I quoted getting the back end off my car painted. The quote came out for more than it costed to buy a 20 gallon compressor, a nice HVLP spray gun and all the paint needed. I sprayed the car myself and it looks darn nice. Another example would be to quote a couple of timing belt changes and tensionings. That quickly justifies spending $$ on a P9201 tool.
just my $.02 worth. and it works when you are married too!!!
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Haha, hey my car does need a repaint, and I have a parts car to pratice on...
Heres a question : How well do air drills work. If i want to take off say, my calipers, are they going to have trouble with the bolts that hold them in place?
hi scheistermeiste. yes, you can borrow many a tool, but i like to have all my tools in one place, at the ready! unless of course, they have a pukka tensioning tool!!
i tend to go with the same ethic i use at work. i have all the tools i need to do my job, and i'm sure most mechanics are similiarly equipped.
That Guy
Forget Craftsman and Mac, SnapOn all the way! I just hope you have $50k to spend on the full mechanics setup.
Seriously though Craftsman are good, reasonably priced, and though they do break from time to time...Sears is only 10 minutes away. Id only buy a full set of SnapOn's when i win the lottery or worked with these tools for a living. Otherwise Craftsman are more than adequte for a backyard mechanic. I brought them a rather large breaker bar bent at a 45 degree angle. They replaced it without even a funny look. Id go with a starter set from Sears, something around the $150-200 range. I bought a great starter set while it was on sale last year, includes all different sizes of sockets and wrenches...etc. Id then buy a set of the universal flex sockets as they come in very handy when working in tight areas. Remember to pick up a good floor jack and atleast 4 jackstands. A quality Torque wrench and a selection of different breaker bars will come in very handy also. From there i would just go about buying what you need, as you need it.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
I can't emphasize this one enough: Set of metric racheting gear wrenches. When working on these cars, they make working in tight spaces a dream. Also get a good 3/8 AND 1/4" rachet set. I use the 1/4 set just as much as the 3/8" I 2nd the craftsman for the majority of the tools you wil use a lot, if they break, easy and free to replace. For things like triple squares that you use once in awhile, buy a no namer. I am still on the same $1 8mm triple square bit and it looks brand new and has been through a few tranny swaps and 2 clutch jobs.
Doc Wilen 86 951 |
Oh and with craftsman, they dont even ask, they just replace it. I broke a 3/8" rachet once, (so i had a 5 foot breaker bar on the end of it, big deal, and was out in the field and it was the only wrench i had), it was literally in about 6 pieces when i laid it on the counter at sears, he smiled and handed me a new one and i walked out. i was in the store for probably 2 minutes tops.
Doc Wilen 86 951 |
Custom User Title
Damn, so tell me again why I just bought a 27 inch 1/2 breaker bar?
I too would vouch for Craftsman, I have been using my 1/4 3/8 set and have been adding on as required. Last week I got my breaker bar, torque wrench and 1/2 sockets (still need the rachet) From a power tools perspective I have a Circular saw, chop saw, router, corded drill, cordless drill, jig saw and a cordless screwdriver. I would like to get a compressor and air tools next... Mwah ha ha ha ha! |
Snap on 3/8 and 1/4 ratchet small profile............ Awesome for tight fit places.....and STRONG
Torque wrench 3/8 and 1/4 .......... Metric sockets, hex, cheesehead .... Metric wrenches. BUY THE BEST YOU CAN. Its worth every penny.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
im all about mac because my cousin has an almost complete set, including air tools
WOOT! post 801!
