Horn Issue
When I bought my 88 924S there wasnt a horn in it (low or high) I found the terminals for the horn and tried to get a reading off of them with my multimeter, but everytime i press the horn switch... the on-relay fuse blows (16 AMP) Any ideas what could be causing this, there are no visible shorts in the wiring.
You most likely have a fault in the horn button or somewhere in the wiring.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
it may be a faulty relay as well.
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
You probably have a faulty horn/s. Disconnect all the connectors from the horn/s and try again.
Regards Misty
924, 1983 |
