fast924S's Avatar
Send a message via AIM to fast924S
Gotta love clean/new engines
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-29-2004, 08:47 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
OOOOOO AHHHHHH!
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 11-29-2004, 08:48 PM
livewirevoodoo's Avatar
what does something like that fetch on the street these days?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
fast924S's Avatar
couldnt tell yea, not my engine, it would depend on the work and products used
Old 11-29-2004, 08:53 PM
Yep she sure is sweet!
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 11-30-2004, 05:29 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Which pistons are those? They don't look stock. Well, that or the picture in my head of stock pistons is wrong =)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-30-2004, 06:57 AM
fast924S's Avatar
I think they are turbo pistons
Old 11-30-2004, 02:07 PM
Zero10's Avatar
Well, I've never actually seen a set of turbo pistons, I thought they had the same crown design though. But it's quite possible that I'm wrong =)
Buy my parts!
Old 11-30-2004, 02:28 PM
fast924S's Avatar
i could be wrong too, Im not sure what they are but with the deep dish in the middle of the piston I just guessed they where turbo pistons
Old 11-30-2004, 02:30 PM
ae1969's Avatar
Send a message via ICQ to ae1969
....aftermarket turbo pistons and wet sleeves.
Not cheap.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-30-2004, 03:19 PM
fast924S's Avatar
How can you tell if those are sleeves??? Whats is a wet sleeve?? I NEED TO LEARN MORE
Old 11-30-2004, 05:47 PM
throw away your mirror, you can shave looking at those things.
1988 924s mars red
coastal cruzer
Old 11-30-2004, 05:59 PM
ae1969's Avatar
Think of this way....... For a dry sleeve we would bore out the existing cylinder. So its a liner........ pressed in to the existing cylinder with an interference fit. So no coolant comes in contact with the sleeve (hence dry). One of the big challenges with these blocks when sleeving is the dissimilar metals with different expansion rates!
A wet sleeve on the other hand completely replaces the entire exisiting cylinder..... machined to fit. The entire new cylinder is surrounded by coolant. One of the dilemnas with the wet sleeve design is that the sleeve takes all the force! With an open deck design we have no support up top to begin with......... Not good.
One of the major problems with our blocks is the open deck design.... If someone made a closed deck design block for our cars it would be a dream!!!!
Old 11-30-2004, 06:40 PM
Zero10's Avatar
How do you know they're sleeved? Is it because the cylinders are so close together?
Buy my parts!
Old 11-30-2004, 07:33 PM
Send a message via AIM to bluebullet
possibly..but i have seen that on honda motors..they bore out the entire sleeve and press fit the new one in. Usually has a block gaurd built into the top of it so it sits down against the top of the motor, turning the open deck design into a closed deck.
Im sure someone out there makes sleeves that butt against each other and the block itself for the Porsche. How could a 951 run a stupid amount of boost with out cracking the wall?
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 11-30-2004, 07:37 PM
ae1969's Avatar
Thats exactly it Zero. Good eye. They are closer than the stock cylinders.
Blue ...
Unfortunately our market is behind the import/domestic crowd in regards to closed deck designs..... no such thing as modular integrated deck sleeves for these cars.
PD (performance developments) is making a deck plate for our blocks that runs approximately 1000 bucks...........OUCH.
I only know of one project that incorporated an integrated deck like you mention ..........and the idea was to siamese them together.
To accomodate the large sleeves.... the original block is overbored and you are left with a very small amount of material on the bottom 1/3 of the cylinder. The liner was supported on the head stud bosses to keep from moving side to side and an interference fit and with the head also providing some vertical clamping as well....
One of the problems is the bottom of the 944 blocks becomes PAPER thin to accomodate large sleeves! Unlike honda and ford blocks. The support can be made at the top but the bottom is relatively thin.
Old 11-30-2004, 08:24 PM
