-   -   where does the rear speaker wire run through (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/195352-where-does-rear-speaker-wire-run-through.html)
friendlyguy64 12-05-2004 05:48 AM
on an 87 924s where do the rear speaker wires run through the car?Is it under the trim of the door?
scheistermeiste 12-05-2004 06:47 AM
yup, runs up on the inside of the car threw a rubber gromit to the inside of the rear quarter panel
friendlyguy64 12-05-2004 10:11 AM
where does it run inside the car though?by the doors?
scheistermeiste 12-05-2004 11:16 AM
it runs under that little black plastic piece that is the door seal then meets up with more wires above the kick panel.
friendlyguy64 12-05-2004 03:42 PM
is it only on one side or both sides?I saw two sets of cables,one with black tape around it and the other one with tan are those both for the speaker
scheistermeiste 12-05-2004 06:24 PM
what do you mean by both sides? and if i remember correctly the speaker wire had the take around it.
