friendlyguy64's Avatar
where does the rear speaker wire run through
on an 87 924s where do the rear speaker wires run through the car?Is it under the trim of the door?
Old 12-05-2004, 05:48 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
yup, runs up on the inside of the car threw a rubber gromit to the inside of the rear quarter panel
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 12-05-2004, 06:47 AM
where does it run inside the car though?by the doors?
Old 12-05-2004, 10:11 AM
it runs under that little black plastic piece that is the door seal then meets up with more wires above the kick panel.
Old 12-05-2004, 11:16 AM
is it only on one side or both sides?I saw two sets of cables,one with black tape around it and the other one with tan are those both for the speaker
Old 12-05-2004, 03:42 PM
what do you mean by both sides? and if i remember correctly the speaker wire had the take around it.
Old 12-05-2004, 06:24 PM
