Removing tie rod end
Topic says it all... When i try to loosen the nut that keeps the tierod end connected the whole bolt just moves with it and nothing happens. Is there a 'trick' solution to this, or is removal/destruction the only way out?
Old 12-24-2004, 07:25 AM
AFJuvat's Avatar
Try using a set of vice grips on the top and bottom of the tie rod end and compress. THe added pressure keeps the end from rotating, allowing you to remove the nut.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-24-2004, 10:59 AM
or jam a pickle fork or large screwdriver in there and put pressure while you turn the nut, will do the same thing.
Doc Wilen
86 951
Old 12-24-2004, 11:05 AM
