Lug nut help!
I have some of those aluminium style lug nuts but they dont fit on the 944's studs. they are too long. what gives?
Old 01-01-2005, 12:51 PM
Hmmm, need more info...
What year car, front axle, rear axle, what kind of wheels, what kind of lug nuts, pix of the problem???
Any clue you can give might be able to help us figure out what is wrong...
gb
Good luck, George Beuselinck
Old 01-01-2005, 01:08 PM
of course you would ask that.
i have no idea. here is a pic.
simply i have some brakes from a 944, the studs are longer than the aluminium style nuts i have.
you can see the studs come all the way out to the end of the holes.
like what i got
Old 01-01-2005, 03:45 PM
Ah, that's a bit more information...
You can buy the steel lug nuts that don't have tops, or you can buy
spacers to put between the hub and the wheel to use the lug nuts that you have shown here...
gb
Old 01-01-2005, 04:48 PM
SoCal Driver's Avatar
Or you can buy the correct length studs for your particular application.
Or a combination of all of the above.
Actually it's not the lug nuts but the studs, wheel hub depth and a spacer if required.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-01-2005, 04:53 PM
crap not what i wanted to hear!!!!!
there are no long nuts with caps?
i dont wanna change studs, and cant do spacers, look at my fender
Old 01-02-2005, 01:18 PM
Sorry, life's like that...
gb
Old 01-02-2005, 01:53 PM
meister member
speedracing944's Avatar
I know on my 83 944 there are about 1" spacers between the brake rotors and the rims. Your brakes are off of a similar car. You will need to fit shorter studs in order to use the lug nuts you have.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-02-2005, 06:14 PM
meister member
Or if you want to donate those new lug nuts to the "speedracing944 wants new lug nuts fund" i would appreciate it.
good luck.
Speedy
Old 01-02-2005, 06:16 PM
maybe i can trade my rotors to someone who need long studs?
Old 01-02-2005, 06:23 PM
meister member
what about drilling out the front of the lug nuts so the end goest all the way through?
Old 01-02-2005, 06:30 PM
that would not look cool
Old 01-02-2005, 06:37 PM
meister member
what about pulling the studs out and shortening them by turning them on a lathe? If you have access to a lathe and 2 hours time it could be done easily.
i am trying to think of "inexpensive" sugestions
i wish you luck
Speedy
Old 01-02-2005, 09:13 PM
winter-hater club member
nynor's Avatar
what about just cutting the ends of the studs off with a saws-all? :P
"COOL PRIUS!" - Nobody Ever
Old 01-03-2005, 05:27 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
If the studs are hardened, would probably be best to cut them with a cutoff wheel and lots of coolant. Don't want to mess with the properties of the metal for something so important.
nate
1988 944... and a bunch of other cars
Old 01-03-2005, 06:54 AM
If you can get the studs out to cut them you can replace them with shorter as is the correct methode.
Old 01-03-2005, 06:55 AM
If you cut them, I would run a die onto the stud first. That way you have a method of straightening out the boogered threads.
I always do this when I have to cut a bolt. Otherwise it's harder to get the nut started.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-03-2005, 08:53 AM
absolutely, also knock the corner off on a grinding wheel if they are out of the hub, before you run the die on, this will help getting the nuts started.
nate
Old 01-03-2005, 09:59 AM
who said pull them out before cutting?
Old 01-03-2005, 11:43 AM
