Did the cam housing yesterday. Belts next. I know the piston is at TDC but looking into the hole above the starter, (Two holes actually?) there is no mark on the flywheel? (Automatic) What's up? Is there another hole?
I'm t'rying to visualize it. There is one hole Slightly offset to the drivers side of the caron top of the bellhousing, kind of behind the oil filler/breather tube. There is a pointer in there that almost touches the flywheel.
__ OT In the upper opening.... otherwise get under the car and there is a notch cutout on the flywheel as well that you line up with the bellhousing... You can line up the mark on the bottom. |
| All times are GMT -8. The time now is 07:22 PM. |
