timing adjustment
i replaced my cam housing gasket on an 83 944. from reading articles on this site after i had already started i learned i started wrong. i didnt set the engine to tdc. but i put the cam housing back on, with the rotor in, hopefuly, the same position. the car runs like what it used to so it must be close. now how can i check the timing to make sure it is right on?
Old 01-11-2005, 04:30 PM
TCMdocs944's Avatar
Year and model of Porsche?
If you took no belts off you are fine. If you took off the belts without aligning tdc etc. and you are running fine....I am amazed.
These cars have no timing to "set"...it is either on or your valves are gone. The balance shafts on the other hand, are a different story. They can be very off without hurting the engine, you will just experience vibration.
Try to put your year and model in your signature line so we can help you better in the future.
Welcome to the board.
Mark
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 01-11-2005, 04:38 PM
83 944
i had to remove my timing belt to remove the cam housing. are there alignment marks i can use to make sure i didnt put the belt on a couple groves off
Old 01-11-2005, 04:44 PM
Firstly, buy a book before working on these cars, or check out Pelican technical articles or Clarks Garage. Broken belt 944s are worth less than $500.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-11-2005, 05:50 PM
a broken belt 944 is worth less than $500...worth repeating
Tom
Early '85 944
Old 01-11-2005, 06:50 PM
pokey's Avatar
Send a message via AIM to pokey
Clarks garage has good diagrams of the timing marks you are looking for. One is visible on the front of the cam sprocket thruogh the little hole next to the dist. cap. The other is a little awkward to see sometimes. It is on the flywheel visible through a hole in the bell housing at the back of the engine. Lay accross your driver side fender, and line your head up at the firewall about 4 inches to the left of the center line of the car, and look down with a flashlight. The markings on the flywheel are generally pretty faint, so look carefully. (The trick is to line up the mark on the cam sprocket first, then go looking for the one on the flywheel.)
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 01-11-2005, 07:06 PM
fred cook's Avatar
Cool 944 Cam Housing R&R.....
I just did this job for a neighbor last Saturday. In addition to aligning the cam gear timing mark and the flywheel mark, I use a piece of chalk to mark the timing belt so that I am ABSOLUTELY certain that everything is synchronized. With a little effort and the right tools this job can be done without pulling the radiator, hoses or fan assemblies. The only part that is stressful is getting the timing belt retensioned correctly since the working room around the adjustment pulley is limited. By the way, Porsche says to install the head to cam box gasket dry, but adding a ring of loctite sealer on both sides of the gasket at the high pressure oil hole will keep things dry a lot longer!
Fred Cook
'80 911SC coupe
'88 924S (gone to a new home)
Old 01-11-2005, 07:46 PM
SoCal Driver's Avatar
I would have replaced the timing and balance belts too. Thought there was a rubber sleeve that goes between the cam galley and the head for the high pressure oil.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-11-2005, 11:35 PM
fred cook's Avatar
Cool Cam Housing Gasket.....
I have had two different 924S engines apart and neither of them had a "rubber sleeve" in place to seal the oil gallery between the head and cam housing. However, since I am fairly certain that both engines had been apart before my turn, it could have been left off by a PO. I don't recall having seen an oil gallery seal in 924S/944 head gasket sets now that I think about it. Anyway, if the mating surfaces are straight and clean the gasket is all that is needed to keep the oil in the engine.
Fred Cook
'80 911SC coupe
'88 924S (gone on to a new home)
Old 01-12-2005, 04:19 AM
Must be my old VW engine rebuild days getting in the way of my recollections.
Old 01-12-2005, 08:12 AM
amazing
i lined up my marks and i was only 1 tooth off. thanks for the help
Old 01-12-2005, 11:34 AM
TCMdocs944's Avatar
Wow....very lucky.
Old 01-12-2005, 12:01 PM
i guess i just do good work
Old 01-12-2005, 01:05 PM
pokey's Avatar
One more tooth and you were looking at valve replacement$$$$$$$$
1956 Ford F250
1955 BMW R69
Old 01-12-2005, 01:23 PM
one more and it would of been right on
Old 01-12-2005, 08:18 PM
Hugh is right, the 944/924S uses an O-ring on the cam housing which is
999 701 602 40, a smaller O-ring for the oil gallery 928 105 184 00, a thin plastic seal for the sleeve to cam shaft 944 105 321 00 and a cam seal 999 113 282 40 (depends on year). All 944/924S 8V engines use these parts and without the large o-ring the housing will leak oil.
Old 01-12-2005, 08:40 PM
O-ring? On the front and rear covers -- right?
I was thinking of the high pressure oil passage right over the oil cooler area that feeds the lifters. Mabe it looks like the later VW oil cooler seals????
Old 01-12-2005, 09:50 PM
Hugh, the O-rings are only on the front cam housing cover. The rear plate on the cam box uses the leak-prone cork gasket. The oil feed to the lifters is more to the rear of the cylinder head and the cam box gasket seals that..most of the time. Check out the Porsche parts catalog and you'll see exactly where it all is.
Old 01-13-2005, 06:26 AM
Send a message via AIM to hpaulb
I got a head gasket kit and have installed all parts eccept one. It's a large rubber "O" ring about 2.5 inches accross. Anyone know were this goes.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-13-2005, 09:21 AM
pokey's Avatar
Thermostat?
1956 Ford F250
1955 BMW R69
Old 01-13-2005, 04:18 PM
