-   -   Clunking and needing help with nut. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/201188-clunking-needing-help-nut.html)
nedvideo 01-12-2005 10:10 AM
First of hello, been reading the board a few times and finding it helpful, so thankyou.
My 1985 924 makes a clunking sound when i go over 'things' (dead bodies etc), more specificly from the front drivers side. The steering is very instant with no play in the steering wheel.
Is this a worn bush? If so, how easy is it to fix as i am quite new to this?
Also, any tips for getting a nut off which has been abused? (I called it a miserable hector which it took offence to, but in addition to this the nut is no longer a nut, more of a round thing).
SoCal Driver 01-12-2005 04:07 PM
Tighten the top of the struts. Check to see that your sway bar bushings are good.
Taz's Master 01-12-2005 04:41 PM
PB Blaster, and vice grips can be useful. If all else fails (and it does from time to time), I resort to a Dremel Tool and an abrasive cutting wheel.
nedvideo 01-15-2005 08:04 AM
Thankyou both.
pb blaster? i dont know what that is.
AFJuvat 01-15-2005 08:51 AM
If you are in Europe, use Wurth Rost-Off - very similar.
AFJuvat
ronin 01-17-2005 12:11 PM
Rost Off works just as well in this hemisphere ;)
