Clunking and needing help with nut.
First of hello, been reading the board a few times and finding it helpful, so thankyou.
My 1985 924 makes a clunking sound when i go over 'things' (dead bodies etc), more specificly from the front drivers side. The steering is very instant with no play in the steering wheel.
Is this a worn bush? If so, how easy is it to fix as i am quite new to this?
Also, any tips for getting a nut off which has been abused? (I called it a miserable hector which it took offence to, but in addition to this the nut is no longer a nut, more of a round thing).
Old 01-12-2005, 10:10 AM
SoCal Driver's Avatar
Tighten the top of the struts. Check to see that your sway bar bushings are good.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-12-2005, 04:07 PM
PB Blaster, and vice grips can be useful. If all else fails (and it does from time to time), I resort to a Dremel Tool and an abrasive cutting wheel.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 01-12-2005, 04:41 PM
Thankyou both.
pb blaster? i dont know what that is.
Old 01-15-2005, 08:04 AM
AFJuvat's Avatar
If you are in Europe, use Wurth Rost-Off - very similar.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-15-2005, 08:51 AM
vott does ziss do?
ronin's Avatar
Rost Off works just as well in this hemisphere
Old 01-17-2005, 12:11 PM
