Where can I get the bit/socket 4 cv's
Just wondering where I can get the tool to take off the cv/half shafts. Also what is the amount of pts?
I got mine at a local VW parts supplier, but some tool stores carry them. Or, you can try Pelican Parts!
It's an 8mm 12-point socket for "cheesehead" bolts, also known as a "triple square" socket.
Jeff 78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
http://store.yahoo.com/joeztools/12pointbitset.html
It's a set of four different sizes for $11.50, and you may need the other sizes on different parts of the car. I also got my circlip pliers from there - they are not very good, but did the trick - and they were cheap!
Andy Lowered '84 944 no longer smokin! Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!) http://photos.yahoo.com/shineyblue944 |
I got a nice set from Pep Boys for about $20 . 6mm, 8mm, 10mm and 12mm.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
Advance Auto, in a 3-pack
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
O'Reilly has them too, the 4 pack of bits of different sizes. One of the mechanic guys probably has the Snap-on part number. The cheap bits will do the job, but if you strip one of he CV bolts you'll be kicking yourself for not paying $20 for the right tool. I believe CV bolts cost $8 each, is that right?
edit: The one you want is an 8mm 12-point (triple-square): http://buy1.snapon.com/catalog/item.asp?item_ID=2480&group_ID=282
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Snap on part number FTSM8E
You can also web search for XZN fastener (proper name for the bolts) AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Parrothead member
I changed mine over to regular 6-point socket head stainless bolts
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
CV bolts are a little under $1 each.
The triple square drive is one tool you probably don't want to go cheap on. Unlike allen head bolts the depth of the engagement splines in the bolt heads are fairly shallow. This gives more meat to the head thickness in the shoulder. But it also means it is easier to round out points if your drive is low quality and doesn't fit snug. |
Napa calls it a star socket bout $8.
Advance auto has the 3 pack for about the same price (other sizes fit door stays etc.) Clean out the heada (female surfaces) and give a little tap to seat them before turning. They should not be in there with much torque so don't force them.
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
meister member
I chased down a Snap On truck. for 4 triple squares they were $120. OUCH!!
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
I thought the CV bolts were waaay more expensive than that... wonder what I'm thinking of.
meister member
I think the tensile strength of a 6 point (Allen) stainless bolt is much much less than triple square bolt. That could prove to be dangerous if they broke while going all out down the back straight. If I remember correctly the triple square has one of the highest tensile strengths for a fastener. Speedy
Parrothead member
meister member
I checked into the tensile strength of both the metric stainless socket head cap screw and a class 12.9 metric socket head cap screw. Here is what i have found. stainless metric = 100,000 psi tensile strength Rockwell hardness B100 12.9 hardened steel metric = 176,900 psi tensile strength, Rockwell hardness C38-44 torx are rated even higher at 180,000 psi and I think the triple square bolts are higher yet. hope this helps, Speedy
Parrothead member
Thanks Speed! I guess the info I got was off a bit.
