Right Rear fender removal?
Ok i need to get the rear fender off my parts car so it can be put on the one that just got wrecked
. Anyone know how i go about doing this? thanks
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Non Compos Mentis
Start cutting. It's part of the unibody construction.
A sawzall with a metal blade works fine. I suggest you have the replacement parts in hand before you start to make sure you leave enough metal to weld the new parts on. Major bummer if you cut one inch too much! Last edited by Dantilla; 02-05-2005 at 01:23 PM.. |
so theres no way to just remove it?
you may be better off fixing the other car
There is, but it involves a saw as mentioned before. I have some good pics of the process, but I can't seem to find them right now.. The only pic I can find right now just shows the car with the new fender on, you can tell its a different color. Look at the 931 in the background behind the 951. I'll keep looking and see if I can find the pics showing the whole process.
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
Wolf man if you can dig those up, it would be a LIFE saver. As it stands now, ill be cutting away what part of the fender is hitting the wheel, and driving that way... as soon as I get a replacement wheel. Ill upload pictures in a few, and people can survey the damage.
You should first find a lawn chair. Get your favorite drink. Then sit yourself down, and direct your brother how and where to do the cutting.
_____________________ Cars |
OOoohhhh, I found another pic......now if I could just find the rest of them...
if that 2nd picture was taken on the same day as the removal of the fender, then do a search for *.jpg created on (whatever day the others are)
Well, that would be wayyyyyyyyyyyy too easy. The pics are on still on discs....somewhere!!!
thats fine, if you find them let me know, if not, run out and take some pictures, and use paint to draw some lines where i need to cut
thanks alot man. Really appreciate it.
If at all possible I would get a skilled body guy to repair the fender that's on the car.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Yes, if its repairable have it repaired!!!!!!!!!!! Replacing an entire rear quarter is not as easy as it sounds, and not nearly as much fun as you might think.
Heres a few pics!!!!!!!!
Is that where the seam is supposed to be on the C-pillar?
Did you drill the spot welds and such out? Or, how did you remove it?
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
