throttle cable adjustment
I noticed that the throttle cable has a little slack in it since I put a new throttle cam on it. Where exactly do you adjust the cable from? I know its loose since there is a little play when I press the gas till it actually opens the throttle.
Old 02-16-2005, 03:58 PM
AFJuvat's Avatar
Follow the throttle cable back to the firewall - youwill see two jamb nuts to adjust the cable with (13mm I believe)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-16-2005, 08:30 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
adjust those jamb nuts! You want the throttle cable to be as tight as it can get without permantly holding the throttle a little bit open (in other words, you want it just loose enough so that when you let off the gas the revs will drop to idle).
Otherwise you are just killing your throttle response.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-17-2005, 06:22 AM
sayporsha's Avatar
There are 2 adjustments you need to make:
1.) Take the slack out of the cable at idle. You make this adjustment with the 2 nuts where the throttle cable exits it's sheath by the throttle body.
2.) Adjust the gas pedal stop to ensure you are acheiving wide open throttle (WOT). Have an assistant hold the gas pedal to the floor, then see if you can open the throttle plate any more by hand. If you can, adjust the gas pedal stop down to ensure WOT. Caution: Make sure the gas pedal stop (not the cable) stops the pedal travel, not the cable. If the cable is stopping the pedal, it will stretch & possibly break.
Jeff
78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
Old 02-17-2005, 05:49 PM
