Idle questions
hey everybody!!!
quick question, my car idles at 1200 rpm and whenever i gas it up to 2k rpm, it takes a while for the engine to go back to idle....maybe about 5-8 seconds, sometimes even staying at 2k rpm for that time before going back to idle......what could be the problem? thanks again.......SmileWavy |
Where in Sacromento are you Enthuzed1?
Also what year and model is your Porsche? |
is your throttle cable too tight? The throttle body might not be clicking back to the closed position. Try just loosening the throttle cable just a little.
duh!! :rolleyes:
thanks cj, that's probably the problem/solution, now i just have to get a new throttle return spring cuz i was trying to examine it and dropped it , and now i can't find the damn thing:mad: hehe, oh well, what can you do? oh, also, does the the throttle pulley touch the return spring on WOT? Because mine does...... hey pca, i'm over here in Elk Grove, but will be moving to Concord soon....cool, i have a bunch of friends who go to Davis, you ever ate at Fuji's? I loooove their Sushi......... |
Not relevent, but I drilled the Kaiser Hospital in Elk Grove. They're about to do a huge expansion project.
drilled? hey, you don't do retail stores do you?
sport chalet ring a bell? |
| All times are GMT -8. The time now is 06:37 PM. |
