Send a message via AIM to ike229
Clunking from rear while under acceleration
My car just started making a nice clunk today. The sound comes from the rear right of the car. The sound only occurs under acceleration and speeds up as i accelerate. Clunk ... clunk... clunk. I read another post and someone with a similar problem found it to be their hand-brake... which doesnt sound quite right, as it only occurs under acceleration, while in gear.
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 03-02-2005, 06:53 PM
ae1969's Avatar
Send a message via ICQ to ae1969
CV....... Raise the car and all will become clear.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-02-2005, 07:01 PM
Burn the fire.
Brando's Avatar
First... is it a discernable, deep metal-sounding "Clunk" or more of a warble?
Could be:
Brake rotors rubbing on pads/calipers
Wheel Bearings shot/starting to go
CV Joint busted/needing replacement.
See if you can reproduce the sound outside of the car. Get the rear end in the air and on jack stands... turn the wheels while in neutral to see if it really is the right-rear axle, or the trans or where exactly it is coming from.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-02-2005, 07:06 PM
Burn the fire.
Brando's Avatar
Addendum:
Also, another trick to tell where a noise is coming from is to take a long plastic-handled screwdriver (24") or breaker bar and rest one tip on a solid point, put your ear on the plastic part. If you can hear the vibration or clanking very very VERY clearly in whichever location you can find it easier like that.
Old 03-02-2005, 07:07 PM
Check them wheel bearings, too.
drew1
wife has 924 turbo
Old 03-02-2005, 08:11 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
First I would raise the rear and check the wheel for any slop. Rear axle nut will back out if it was removed at one point then re installed. They are lock nuts.
Then look at the CV joints. These will clunk but usually during cornering when it is most noticable but not gospel.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 03-03-2005, 12:52 AM
cv's is my guess...save yourself the trouble if it turns out to be that and buy complete axel assemblys....
repacking those bad boys aint fun...
Current: 1973 914/4 project. FOR SALE
Old 03-03-2005, 06:34 AM
TSNAPCRACKLEPOP's Avatar
i rebuilt mine, reversed the wear pattern of the bearings after a thorough scrubbing, regreasing with hi temp grease. i would only do this if all my bearings and cages were in very good condition without scoring. now no noise, car has been driven about 10 k miles.
rebuilt ones do not cost that much if you do not feel confident doing this.
dr t
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 03-03-2005, 07:13 AM
TopsailBeach's Avatar
Mine had the same symptoms--clicking/clunking during acceleration.
There are shops that will rebuild them for you--check out the yellow pages. I took both axles to the shop and they rebuilt them for $147. No core charge, no shipping and was completed in 2 days.
Second best part of the experience: the call after they had disassembled the first cv with the question, "Tell me again what kind of Volkswagen this came from?"
The best part is the tightness that returned to the entire car after installation. The difference is remarkable!
A J Burns
'07 Guards Red Carerra 4S 911 Coupe w/Aerokit
'86 Iris Blue Carerra 911 Coupe (given to my son)
'63 Morgan Tiger Cub w/original Atomic 4
Old 03-03-2005, 04:23 PM
xero's Avatar
yeah my car does the same thing, it's the cv joints, does it all the time turning or not....i've been told that you can get the cv joints from a vw bus and put them on your axles and they're actually stronger than stock 944 cv's ??
Old 03-04-2005, 01:32 AM
