-   -   Ignition Kill Switch in Center Console... Possible? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/210220-ignition-kill-switch-center-console-possible.html)
livewirevoodoo 03-09-2005 08:06 PM
I'm looking into the possibility of using one of my center console blanks for an ignition kill switch. Currently I have Rear Wiper, P Windows and P Sunroof switches in the console.
Can I buy, say, another power sunroof switch and wire it for an ignition kill switch? It is a 6 pole connector. Looked @ haynes wiring diagram - not much help. Anyone familiar with the pin-outs on these switches?
Hoping for a little direction.
Thanks in advance.
AznDrgn 03-09-2005 08:24 PM
Here's a write up on how to do it, where you put the switch will be your choice but I doubt one of those small switches will be able to handle the amperage load neccessary.
http://www.pelicanparts.com/techarticles/Mult_ignition_cutoff/Mult_ignition_cutoff.htm
livewirevoodoo 03-09-2005 08:43 PM
so better off going with just something mounted under drivers dash then, huh? I guess it server the same purpose.
I was looking to fill the center console with options... lol
AznDrgn 03-09-2005 09:32 PM
Get creative, if you don't smoke redo the cigarette lighter to make it a switch or do something fun with it. Just think James Bond car and lots of interesting ideas for switches will come to you.
adrian jaye 03-10-2005 03:57 AM
if you use a relay then you dont need to worry about amperage
MoonBoy 03-10-2005 04:20 AM
I just bought a car with a kill switch in the console, I would have never found out if I hadn't been playing with the switches while the car was running. Moral of the story, if you do this and sell the car, tell the next owner. ;)
AznDrgn 03-10-2005 07:09 AM
This is true but to someone new to wiring adding a relay into the mix is normally quite confusing not to mention the fact that you have to run a lot of extra wiring straight from the battery or the panel.
Zero10 03-10-2005 08:36 AM
I did something along a similar line in a previous car.
I had a button you had to hold down while you started the car.
It was one of my home-made anti-theft devices. It would kill the fuel pump unless it was held down until the ignition switch was turned back to the on position from start.
Mind if I ask what your motivation for this is?
It would be pretty simple to do. Perhaps the sunroof switch is the best choice, since it's the only one I can think of that returns to the center position when released.
If you have a multimeter, just measure the resistance between pairs of pins until you find a set that is connected when you push the switch in the desired direction.
livewirevoodoo 03-10-2005 08:52 AM
Zero -
Basically my motivation is to feel sure that when I step outside for work in the morning my car is where I left it. Audible alarms dont give me that warm & fuzzy feeling. A killswitch will leave me feeling a little better off.
I was thinking of a rear window wiper switch actually. So the connection is either 'on' or 'off'. Based on the setup you had, I can see the usefulness of a "hold down sunroof switch until ignition' setup. Although that would require 2 hands to operate if the switch was in the center console.
