Verruckt's Avatar
Engine Swap/Upgrade
My 2.5L has sucked the #1 ring into the oilpan, and trashed the cylinder wall.
I was wondering how hard would it be to upgrade to the 2.7 engine. I know the only real internal differance is the bore. The 2.7 has different exaust headers, however, they use the same head to headers gasket so I should be able to use mine. The 2.7 has knock control which I would like to keep for a street car. Wiring would be the issue I believe. The engine I was looking at has the wiring harness dme, and comes complete. Since my 924S has the later (series 2) wiring harness, this should be pretty easy then correct?
I am aware that this does not increase the value of my car, and all the rest. I will be owning this car for a very long time, regardless of which engine gets put into her. Just looking for some more TORQUE down low!
Thank you all in advance,
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 03-11-2005, 08:04 PM
fast924S's Avatar
Send a message via AIM to fast924S
Depending on how bad that cyc;inder was is you might be able to repair it. If you can find a 2.7 its just about the same engine different bore, So it would be a easy swapp. You would not be able to use the knock sensor since the 924S doesnt have one, But you could hook up a aftermarket knock gauge to it just to keep a eye on things. If you do the 2.7 swap make sure you get the AFM and DME then I believe its just a drop in.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-11-2005, 08:49 PM
