-   -   NO, not another broken timing belt-but close... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/210582-no-not-another-broken-timing-belt-but-close.html)
armandodiaz 03-12-2005 06:57 AM
Changing the front seals on my 977na and found this...
http://forums.pelicanparts.com/uploa...1110639368.jpg
http://forums.pelicanparts.com/uploa...1110639384.jpg
The timing belt is walking off the cam spocket and rubbing against cam housing cover. Is there a fix for this?
Please Help.
SoCal Driver 03-12-2005 02:04 PM
Check the belt tension pulley and it's supporting structure. Pulley could be loose. Support stud bent or pulling out of block/tensioner. Or if a spring loaded tensioner, the tensioner arm could be loose. The flange on the timing belt tensioning pulley always goes toward the block.
The water pump pulley/roller could be loose or if a rebuilt water pump not machined correctly.
Always look at the pulley or roller before the trouble spot on toothed belts.
armandodiaz 03-12-2005 03:37 PM
I have found the lower screw that hold the rear cover to the cam housing missing. I also notice some play on the adjusting gear. It's also sound a little rough when I spin it. I'm going to replace these and take it from there.
SoCal Driver 03-12-2005 09:51 PM
The "adjusting gear" is the tensioning pulley?
armandodiaz 03-13-2005 04:46 AM
Yes the gear that is on the tensioner.
SoCal Driver 03-13-2005 09:56 AM
It's not a gear. It's a pulley. Nomanclature is important. Take the headlight motor apart if you want to see a gear. Or the transmission.
Also the small smooth round idlers that just barely touch the belts or come close are called rollers.
IceShark 03-13-2005 12:23 PM
One other thing is if you have that spring tensioner for the timing belt and you haven't done the work on the car from day 1, those bolts can be stripped or near stripped from prior belt work. And the tensioner will then cause all sorts of problems. This is when helicoil is your friend. ;)
SoCal Driver 03-13-2005 06:46 PM
Same as what I'm thinking.
armandodiaz 03-16-2005 04:22 PM
Well I'm ready to replace the tensioner (gear;) ) and I took a close look at the old adjuster:
http://forums.pelicanparts.com/uploa...1111018926.jpg
Is this positioned correctly or is it backwards?
SoCal Driver 03-16-2005 07:26 PM
Should be a washer under the bolt in the upper right. Kind of an elongated washer.
