armandodiaz's Avatar
NO, not another broken timing belt-but close...
Changing the front seals on my 977na and found this...
The timing belt is walking off the cam spocket and rubbing against cam housing cover. Is there a fix for this?
Please Help.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 03-12-2005, 06:57 AM
SoCal Driver's Avatar
Check the belt tension pulley and it's supporting structure. Pulley could be loose. Support stud bent or pulling out of block/tensioner. Or if a spring loaded tensioner, the tensioner arm could be loose. The flange on the timing belt tensioning pulley always goes toward the block.
The water pump pulley/roller could be loose or if a rebuilt water pump not machined correctly.
Always look at the pulley or roller before the trouble spot on toothed belts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-12-2005, 02:04 PM
I have found the lower screw that hold the rear cover to the cam housing missing. I also notice some play on the adjusting gear. It's also sound a little rough when I spin it. I'm going to replace these and take it from there.
Armando Diaz
Old 03-12-2005, 03:37 PM
The "adjusting gear" is the tensioning pulley?
Old 03-12-2005, 09:51 PM
Yes the gear that is on the tensioner.
Armando Diaz
Old 03-13-2005, 04:46 AM
It's not a gear. It's a pulley. Nomanclature is important. Take the headlight motor apart if you want to see a gear. Or the transmission.
Also the small smooth round idlers that just barely touch the belts or come close are called rollers.
Old 03-13-2005, 09:56 AM
One other thing is if you have that spring tensioner for the timing belt and you haven't done the work on the car from day 1, those bolts can be stripped or near stripped from prior belt work. And the tensioner will then cause all sorts of problems. This is when helicoil is your friend.
Old 03-13-2005, 12:23 PM
Same as what I'm thinking.
Old 03-13-2005, 06:46 PM
Well I'm ready to replace the tensioner (gear ) and I took a close look at the old adjuster:
Is this positioned correctly or is it backwards?
Armando Diaz
Old 03-16-2005, 04:22 PM
Should be a washer under the bolt in the upper right. Kind of an elongated washer.
Old 03-16-2005, 07:26 PM
