Window weatherstripping question
I am currently restoring a 1983 944 NA. The weatherstripping looks wrong. Where the top piece intersects with the bottom piece there is a 3/4" gap. I know the car has been repainted by a preious owner. Is some corner piece missing? Has the original weatherstrip shrank over time? I appreciate your thoughts.
"Porsche: It's not a mid-life crisis, it's a life changing experience." 1983 Copanhagan Blue 944 1987 Black 944S - Project |
If you are refering to the rear window track and seal then it's possible this has slipped down into the door.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
The intersection I'm referring to is at the bottom A-pillar side of both the driver and passenger side windows. Thanks for you reply.
