Help! I need someone to look at their block!
As some might know I've been having oil pressure problems for the past 3 weeks. I have done almost everything to correct the problem. Please referr to:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/213360-oil-pressure-problems.html After failed attempts I decided to remove the oil cooler again. Now with carefull inspection I found a potential problem in the block. This is the whole the oil pressure valve lives in. I need someone, who has their oil cooler off, take a look and see if yours is also half circled like this one (Please tell me it is!): http://forums.pelicanparts.com/uploa...1114131893.jpg |
Somebody has to have a block lying around?
Will look for you when I get home from work.
Thanks Hugh
I just checked an '89 S2 block and that is the way it is on there.
THANKS AznDrgn. My heart can start beating again. If you were local I'd buy you a beer.:)
Now back to my original oil pressure problem:( |
| All times are GMT -8. The time now is 01:39 PM. |
