Searching for an item, can you help?
I am searching for a set of urethane 2 piece inner sway bar bushings for the stock application 20 mm sway bar on a 1987 Porsche 924S, could anyone help me with a possible source?
Non Compos Mentis
How about here at Pelican?
944online.com
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
