Window rattle
My driver's side window is loose. At first, I found the felt lining of a window track in the bottom of the door. I reattached it, with glue. Now the window goes down fine, struggles a little more to go up, and is still loose. Is there an adjustment or the possiblility of a loose screw somewhere? I've looked in there as best I can.
All I see is that the window seems to be slightly out of alignment with the tracks: it tends to go inwards, so there's a visible gap between the window and the outside weatherstripping. But I see no way of fixing this. Any ideas?
Old 05-08-2005, 01:22 PM
SoCal Driver's Avatar
I kind of remember that one of the tracks is adjustable. I'll have to look at the spar doors I have.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-08-2005, 04:53 PM
the tracks come loose at the bottom. Especially the one towards the rear of the door. Teh screws seem to back out. It may feel tight when you first look, but its probably needs to be snugged up.
Current: 1973 914/4 project. FOR SALE
Old 05-09-2005, 03:35 PM
Well, I took a close look at the tracks, and they appear to be nonadjustable. Maybe I'm missing something. Something is learly wrong with the window, though: the lining only stopped the rattling noise; the window is still loose. Is there anything that can be adjusted? Thanks.
Old 05-09-2005, 03:37 PM
Oops, I never saw you response. I'll take another look sometime, the door is back together. Thanks.
Old 05-09-2005, 04:03 PM
ae1969's Avatar
Send a message via ICQ to ae1969
THere is a bolt at the bottom but its welded at the top as well....... on the late cars anyways.
The bottom bolt is enough to hold it in place......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-09-2005, 04:12 PM
