What is a DME relay?
I am having trouble with my fuel pump and was told the DME relay is important. What is it? What does it do? Where is it? Thanks
early '85 944 -project car, sort of works.
Old 05-15-2005, 06:58 PM
livewirevoodoo's Avatar
More than you ever wanted to know about the DME:
http://www.frwilk.com/944dme/
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 05-15-2005, 07:14 PM
Fuel pump relay: 993 615 227 00 is a service item that should be changed every 5 years or so.
It is the main power source relay for the Motronic system. When (not if: when) it fails the car stops. Usually at the most inconvenient and annoying time.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-16-2005, 03:14 PM
