fast924S's Avatar
Send a message via AIM to fast924S
Check out these plugs
Hey guys, I was just surfing around and came across these spark plugs, I think its all BS but it is a cool design
http://www.extremespark.com/
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-16-2005, 04:22 PM
Send a message via Yahoo to bigyagi
hmm, not sure if my physics is still all there, but the field-effect is about the two parts of an electrical field, namely the E, and the H field {i think}. they are at right angles to each other, and 90 deg out of phase. they both exist, although i cant think why this would be used in a spark plug application?
the H field is more commonly referred to as the magnetic field.
yes, i know, i should get a life!!
bob.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 05-17-2005, 04:35 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
so, what you're saying is...?
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-17-2005, 04:50 PM
all i can really say, is that the magnetic portion of a "wave front"is exceptionally great at not coupling into other electrical circuits, than the E field does. this is fact. maybe for the plugs, this means less interference if you are listening to say, am radio.
bob.
1984 944 na.
Old 05-17-2005, 06:00 PM
Zero10's Avatar
Send a message via ICQ to Zero10
They look terrible. I can't imagine they would work very well in real life. How would the fuel/air mixture get all the way down inside the plug to be ignited when it sparks?... You would get a lot of misfires.
Not to mention, everything they say seems just a little off.....
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 05-17-2005, 07:28 PM
Send a message via AIM to AznDrgn
That style plug has been around for years in Marine application motors. Part of the idea is that there is nothing blocking the electrode and spark from the fuel air mix.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 05-17-2005, 08:15 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
they probably work as well as the turbonator or the e-ram
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 05-17-2005, 09:12 PM
pokey's Avatar
Send a message via AIM to pokey
It is similar to surface fire or zero clearance plugs used in outboard motors, and also extremely high compression engines, F1 and the like. My buddy built a small block Chevy, short stroke, 14:1 compression 11,000 rpm 714 HP normally aspirated motor, and had to run zero clearance plugs. He had to run an aviation coil that put out 90,000 volts.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 05-17-2005, 10:47 PM
