LAKings's Avatar
Question Oxygen sensor connector trashed
Hello,I have a quick question about the O2 connector at the top center of the firewall.I recently diconnected the connector and it broke into pieces.Can I somehow bypass the middle plastic and directly either solder or connect it together somehow?I really appreciate your help.Thanks.
Chris
'84 944NA
'91 TOY P/U 4X4
Old 05-17-2005, 06:10 PM
Wolf1's Avatar
Welcome !!
And yes you can eliminate the O2 sensor connector, and splice the wire together.
Some people will tell you to only use crimp connectors, some will say solder.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 05-17-2005, 06:16 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
I used a crimp connector with heat-shrink, although some of the heat shrink looks to be coming off.
Probably shouldn't solder: http://frwilk.com/early944/misc/oxygen.htm
Use wire crimps or Posi-LockÒ. All the latest BOSCH O2 sensors are air tight. But the O2 sensor must have a clean air supply to work. It breaths down the center of the multi-stranded wire(s). Solder and solder flux will close the air-gaps between the strands of wire and the O2 sensor may malfunction.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-17-2005, 07:01 PM
pokey's Avatar
Send a message via AIM to pokey
Use crimp on male/female connectors, so you can easily replace the O2 sensor.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 05-17-2005, 07:04 PM
LAKings's Avatar
The green wire has a seperate wire inside.Do I connect both together?
'84 944NA
'91 TOY P/U 4X4
Old 05-17-2005, 08:44 PM
pokey's Avatar
No. One is the shield. Unweave enough to get a crimp on the inner wire, then twist the unwoven part and put a crimp on it, too.
1956 Ford F250
1955 BMW R69
Old 05-17-2005, 09:18 PM
LAKings's Avatar
Do I connect the outer wire(unwoven wire) to something or just leave it crimped loose?I really appreciate the help.
'84 944NA
'91 TOY P/U 4X4
Old 05-18-2005, 08:24 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I twisted and heat shrunk - worked great!
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 05-18-2005, 01:05 PM
Leave loose, it's a shield, and isn't supposed to connect to anything. Just crimp it, or tape it off.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 05-18-2005, 03:08 PM
LAKings's Avatar
Thanks all.
'84 944NA
'91 TOY P/U 4X4
Old 05-20-2005, 11:34 AM
pokey's Avatar
I would connect it to ground. That way the shield will actually do what it is supposed to.
1956 Ford F250
1955 BMW R69
Old 05-20-2005, 08:01 PM
Banned
trick I learned from the Volvo boys
all the newer bosch O2 sensors [3 wire] are ALL THE SAME unit
the ONLY difference is the PLUG on the end
cut off yor old plug
match the black and white wires
and splice
BTW the two whites are both the heater ends so you can reverse them no problem
ford mustang V8 O2 is the cheapest
most chain stores sell them UNDER $50
anyone tryed this on a 944??
sure does work on volvos
Old 05-21-2005, 08:04 AM
It isn't connected to a ground at the O2 itself. The 'theory' behind it is to ground it where the source needs it to be clean, which is at the DME itself. Having it connected at both ends makes it just another ground wire, and gets rid of it's shielding capabilities and could introduce a ground loop and noise, thus making the readings inaccurate.
Jack
Old 05-21-2005, 08:57 AM
pokey's Avatar
I stand corrected...
1956 Ford F250
1955 BMW R69
Old 05-25-2005, 09:21 PM
