speed sensor
does anyone know if you broke a speed sensor on an 89 944 make it not run?
Absolutly.
thanks. Imjust replaced the clutch. i had to beat one of the sensors out. i have a new one ordered but it ain't in yet..ssigh. so i can;t test my new clutch. I must add the clutch job was fun to say the least.
I had to remove the bracket to get the clutch housing off. then i had to drive the sensor out to remove it......it was really stuck. I did mark the position of the sensor bracket before I removed it. Do you reckon it will be close enuff?
| All times are GMT -8. The time now is 04:39 PM. |
