speed sensor
does anyone know if you broke a speed sensor on an 89 944 make it not run?
Old 05-31-2005, 09:31 AM
SoCal Driver's Avatar
Absolutly.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-31-2005, 09:55 AM
thanks. Imjust replaced the clutch. i had to beat one of the sensors out. i have a new one ordered but it ain't in yet..ssigh. so i can;t test my new clutch. I must add the clutch job was fun to say the least.
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 05-31-2005, 10:07 AM
I had to remove the bracket to get the clutch housing off. then i had to drive the sensor out to remove it......it was really stuck. I did mark the position of the sensor bracket before I removed it. Do you reckon it will be close enuff?
4 quarter horses
Old 06-02-2005, 12:54 PM
NO! Your mark in the bracket mount is not enough to assure the correct gap. Sensor has to be about 0.8mm from the flywheel trigger. Use a 0.8mm washer temporarily glued to the sensor tip then adjust the bracket.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-02-2005, 07:21 PM
