repair manual 924s/944
Does anyone have a workshop manual for an 87 924s or 944? This car has drained me of all my money and just when i thought taken care of everything, the timing belt snapped. i have taken very good care of it even tho it pretty much cost me my job. since i spent the last of my money fixing everything else, i dont have enough to even have it towed to the proper place, much less getting it fixed be a repair shop. If someone can provide me with a copy or download of a Haynes or something, that would be great considering that i have to do this myself.
djkoke18@yahoo.com |
Manuals or not it's going to cost you a minimum of $500 if you pull the head yourself.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
$500.00? is that cause of the gaskets and other parts required
Gaskets and valves and the belts -- of course. Does not include machine shop costs as you can lap the valves in yourself to get it back running as cheaply as possible.
You will need a special 6mm extended allen bit 3/8" drive to get the cam housing bolts loose.
i bought all 8 valves and hardware for $48.00 and i have new belts. i saw a gasket set for like a 100 bucks but i didnt think it contained gaskets for the whole engine for only 100 dollars
Got a deal on those valves -- if they are the correct ones. I couldn't find them for less that $40 each. Needed six.
they look ok. i was told they came off a working 944 engine whick is what i have.
is there anything else i need and anything you can add to help this situation out
Used vaves. Mine were new.
May not be lappable. You may have to take it to a machine shop. They may or may not do a valve grind if the valve guides need to be replace.
Subject to how old everything is and how bad,you will need:
Head gasket set, plus the two gaskets for manifold to front pipe. Front engine seal set, with the sleeves for the balance seals. Crank seal and o-ring Water pump, gasket and mounting kit. (includes the thermostat) All the tensioners and rollers AC and power steering belts Timing and balance shaft belt. Probably a distributor cap and rotor arm. Oil and filter The proper coolant. Make sure you have manual printed out and the right tools.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
I didn't have to pull the rear belt cover.
ok. the only things i have on that list were the timing belts and distributor cap and rotor. any idea how much the front engine seal kit is?
thanks everyone! |
Bottom of this page:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_engine_pg4.htm#item21
As an additional on-line guide, the Porsche Workshop Manual is available at http://www.cannell.co.uk/944%20Reference.htm
Recommend downloading the chapter you need due to large file size and long time required in accessing the pages directly.
1986 944 na - Guards Red 77K miles, Outstanding Condition Recent Timing/Balance Belts, Water Pump and Clutch |
I always recommend replacing the crank seal when you go this deep into a 944. The oil pump drive also needs changing too or it will leak..again. As it's only some more labor time and will need doing anyway, should be replaced.
Depending on what is wring, you may not have to change your seals - short answer, if the rear belt cover is oily, you need to change your seals.
You should DEFINATELY replace your tensioners and roller. If yo have one that is siezing up, you will get your belt on, only to have the belt break again in a short period of time. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
