advice on rod bearings
I've got my personal car apart to replace the oil pan gasket, sway bar bushings, motor mounts, brake lines to SS etc. Whats the deal on changing the rod bearings? The car has 98K N\A and the oil pressure is nice in the normal range with out any knocking? Leave well enough alone or change them before a problem?
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
Change them. If you are already that far into the motor you might as well spend the $75 to get a new set of bearings and nuts. I'm almost positive you'll find the number 2 bearing is pretty worn already. The 944 is notorious for eating those bearings up. If you get to the point of hearing knocking you're already too late, the bearing has spun and damage has already happened.
'91 Jeep Cherokee 4.0L HO - Daily driver '83 Callaway 944 2.5L turbo - Soon to be daily driver '83 Porsche 944 NA - sold '78 Porsche 924 NA- RIP '89 Porsche 944 S2 - Parted Looking for a nice 944S for a daily driver. |
Non Compos Mentis
At 98,000 miles, the engine is just broken in for street driving. for sustained high rpm use (racing), cross drill the crank now.
ive decided to check the bearing clearance before ordering parts. anyone know the stabdard clearance for the rod bearings?
you better get a shop manual bro.
'77 924-- It's Alive! |
The bearings come in two sizes, standard and 0.25mm oversize. Most if not all are standard. Check size, buy and install. Problem over.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
