Eldorado's Avatar
another "what is this picture showing" thread by ME!
Alright... decided to pull up the carpet in the trunk to fix some of the back lights... when I yanked it, I noticed two rubber hoses coming from the gas tank filler area... one goes out the bottom of the car and hangs underneath (hose 1)... the other just sits in the back right cubby (hose 2)... could this be the cause of my gas smell in the car?
while I had the carped lifted... found this.... what is it?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-14-2005, 01:47 PM
lm6y's Avatar
Hose #1 Is the sunroof drain tube. Not sure about #2.
Picture #2 Is your fuel tank level sending unit. I had a gas smell in mine, and replaced the gasket on sthe sending unit. The gas smell went away.
Brent
Early85 944
LM6Y Paint Code
Old 06-14-2005, 02:34 PM
strath44's Avatar
Hmm thats interesting hose 2 is missing on mine wonder if thats why I had water in the drivers sill?
I was told the item under the cover in the 2nd picture was a flux capacitor?
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 06-16-2005, 11:58 AM
bearone2's Avatar
i think #2 is the drain for the fuel cap area.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-16-2005, 02:29 PM
pokey's Avatar
Send a message via AIM to pokey
#2 should be pushed through the little hole you see in the bottom of the cubby.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-16-2005, 04:12 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Yeah, if that black circle thingy is not covering that hole, you will smell gas. I would use some sticky stuff to put it back on - not permanent stuff...
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-16-2005, 04:59 PM
bearone2's Avatar
that black circle thingy is a grommet.
Old 06-16-2005, 10:06 PM
Eldorado's Avatar
I know - mine fits snug... i just removed it for sake of the pic.
Kyle
Old 06-17-2005, 02:16 PM
