Anyone know if the 16" fuchs would fit on my early 944...its an early 85 and i have 15" fuchs on there right now...I guess the later 944's were fitted with 16" fuchs. If not, is there some kind of spacer or something i could get? I like the 16's better anyway.
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche |
Custom User Title
I'm pretty sure the 16s would fit no problem
Heres my 84 with 16"Fuchs...
84 Guards Red 944 88 Conquest TSI 98 Pontiac GTP |
meister member
Make sure they are the correct offset and width. Fuchs came in many different configurations.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
The backspacing you will need is 125mm/4.92". The offset is 23.3mm/0.92". I think there are 7JX16 out there with this early offset but I don't know about 8JX16. Anyone out there know? good luck! Larry
yes, the 8x16's will also work on the rear. Tifosiman might also post up and show you how well the 9's work on the rear
![]() just get a set of 951 7's and 8's, they should look killer.
'84 944na -- Sold '84 944na -- Sold '85 944na, -- Sold |
