-   -   part number...? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/225521-part-number.html)
Eldorado 06-08-2005 10:31 PM
part number...?
missing the dome lamp bulb - which one should I look at to replace it?
also, like someone else recently... I need to know how to wire up the lamp. My car came without the whole fixture, and I just recently picked one up and now I need to know how to wire it up... so any help there would be appreciated...
livewirevoodoo 06-09-2005 05:39 AM
dome lamp is a Sylvania 6411.
I'm still looking for a photo, or wiring diagram. Can't find it in the Haynes manual. I've got it working via dome light switch, but not where it turns on when door is open. Anyone?
pokey 06-09-2005 07:37 AM
Check the switches in the door jams. Mine are stuck. They have one Phillips head in each, and are in the front, near the hinges.
livewirevoodoo 06-09-2005 08:14 AM
Thanks for the help pokey. My door jams are good. My problem is one i created - I took the done light out to wash & clean the connections. Didnt mark which wire goes where. So now it works at the switch on the light - either always on, or always off, but not sure where the "door open" wire goes, or even if I have the other 2 wired correctly. I figured if someone could take a quick picture of it wired right, then it should make it that much easier. Thanks for the help tho.
Eldorado 06-09-2005 10:23 AM
I second that request...
anyone have a few seconds to spend doing this for us?
Eldorado 06-10-2005 02:59 PM
anyone? ......anyone? ......bueler? ;)
Eldorado 06-10-2005 03:47 PM
nevermind - figured it out! lol
Eldorado 06-10-2005 04:53 PM
fyi - the 6411 is too wide.. at least it was for my setup... I had to go with a 6418 (I believe - I'll double check that when I get the package out of the car)... it's GE part number C5W...
