Eldorado's Avatar
part number...?
missing the dome lamp bulb - which one should I look at to replace it?
also, like someone else recently... I need to know how to wire up the lamp. My car came without the whole fixture, and I just recently picked one up and now I need to know how to wire it up... so any help there would be appreciated...
Old 06-08-2005, 10:31 PM
livewirevoodoo's Avatar
dome lamp is a Sylvania 6411.
I'm still looking for a photo, or wiring diagram. Can't find it in the Haynes manual. I've got it working via dome light switch, but not where it turns on when door is open. Anyone?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 06-09-2005, 05:39 AM
pokey's Avatar
Send a message via AIM to pokey
Check the switches in the door jams. Mine are stuck. They have one Phillips head in each, and are in the front, near the hinges.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-09-2005, 07:37 AM
Thanks for the help pokey. My door jams are good. My problem is one i created - I took the done light out to wash & clean the connections. Didnt mark which wire goes where. So now it works at the switch on the light - either always on, or always off, but not sure where the "door open" wire goes, or even if I have the other 2 wired correctly. I figured if someone could take a quick picture of it wired right, then it should make it that much easier. Thanks for the help tho.
''87 944na 85k
Old 06-09-2005, 08:14 AM
Eldorado's Avatar
I second that request...
anyone have a few seconds to spend doing this for us?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-09-2005, 10:23 AM
Eldorado's Avatar
anyone? ......anyone? ......bueler?
Kyle
Old 06-10-2005, 02:59 PM
Eldorado's Avatar
nevermind - figured it out! lol
Kyle
Old 06-10-2005, 03:47 PM
Eldorado's Avatar
fyi - the 6411 is too wide.. at least it was for my setup... I had to go with a 6418 (I believe - I'll double check that when I get the package out of the car)... it's GE part number C5W...
Kyle
Old 06-10-2005, 04:53 PM
