-   -   Where does DME get power from? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/225537-where-does-dme-get-power.html)
hughett 06-09-2005 06:20 AM
On late model 944s, 968s...where does the power come from? Directly from the battery? Ignition Switch? Or?
Harvey
AFJuvat 06-09-2005 07:01 AM
Ignition switch
AFJuvat
hughett 06-09-2005 08:13 AM
Thank you!
SoCal Driver 06-09-2005 08:48 AM
Really? Then why does it have a DME relay???
http://www.*****************.com/product_p/pp993.615.227.00.htm
SoCal Driver 06-09-2005 09:18 AM
Should also have one of these that tend to go bad:
http://www.*****************.com/product_p/pp928.602.706.01alt.htm
AFJuvat 06-09-2005 09:25 AM
I stand corrected.
The DME relay gets its power from the battery
The ignition switch closes the DME relay, powering the DME.
Happy?
AFJuvat
SoCal Driver 06-09-2005 09:34 AM
Originally posted by AFJuvat
I stand corrected.
Happy?
AFJuvat
You're scaring me Mike! I hope this was a senior moment.
AFJuvat 06-09-2005 11:20 AM
I knew I shouldn't have huffed all of that carb cleaner this morning....
AFJuvat
ae1969 06-09-2005 01:04 PM
I stand corrected.
Happy?
AFJuvat
OMG this is a sad day. Mother Juvat is indeed human...... :(
There are kittens crying throughout the world as we speak.
SmileWavy
AFJuvat 06-09-2005 04:18 PM
Yeah... I suck.
AFJuvat
SoCal Driver 06-09-2005 05:40 PM
Back to the question. What should have power with the key on.
The injectors and the coil/ignition module.
If there is no voltage to the coil then the ignition switch is not working/bad.
If there is voltage to the coil but not the injectors then the DME relay is not engaging.
If there is voltage to both then the DME is getting it's 12 volts along with the injectors (same circuit). Check that the fuel pump is working during cranking. This tells you that the second set of contacts in the DME/fuel pump relay are being pulled in by the DME as it sees the control voltage going to the starter.
You can check wither the DME is reading the flywheel sensor by getting a NOID light and seeing if the injectors are pulsing. No sensor signal no pulsing.
Report your findings.
SoCal Driver 06-09-2005 05:52 PM
Also need to check the alarm as this will remove power from the DME too.
