hughett's Avatar
Where does DME get power from?
On late model 944s, 968s...where does the power come from? Directly from the battery? Ignition Switch? Or?
Harvey
'94 968 Coupe, 6-speed
'88 928 S4, 5-speed
'85 928 S, 5-speed (Sold)
'02 Audi TT Turbo, 6 speed (Sold)
Old 06-09-2005, 06:20 AM
AFJuvat's Avatar
Ignition switch
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-09-2005, 07:01 AM
hughett's Avatar
Thank you!
'88 928 S4, 5-speed
Old 06-09-2005, 08:13 AM
SoCal Driver's Avatar
Really? Then why does it have a DME relay???
http://www.*****************.com/product_p/pp993.615.227.00.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-09-2005, 08:48 AM
Should also have one of these that tend to go bad:
http://www.*****************.com/product_p/pp928.602.706.01alt.htm
Old 06-09-2005, 09:18 AM
AFJuvat's Avatar
I stand corrected.
The DME relay gets its power from the battery
The ignition switch closes the DME relay, powering the DME.
Happy?
AFJuvat
Old 06-09-2005, 09:25 AM
Originally posted by AFJuvat
I stand corrected.
Happy?
AFJuvat
You're scaring me Mike! I hope this was a senior moment.
Old 06-09-2005, 09:34 AM
AFJuvat's Avatar
I knew I shouldn't have huffed all of that carb cleaner this morning....
AFJuvat
Old 06-09-2005, 11:20 AM
ae1969's Avatar
Send a message via ICQ to ae1969
I stand corrected.
Happy?
AFJuvat
OMG this is a sad day. Mother Juvat is indeed human......
There are kittens crying throughout the world as we speak.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-09-2005, 01:04 PM
AFJuvat's Avatar
Yeah... I suck.
AFJuvat
Old 06-09-2005, 04:18 PM
Back to the question. What should have power with the key on.
The injectors and the coil/ignition module.
If there is no voltage to the coil then the ignition switch is not working/bad.
If there is voltage to the coil but not the injectors then the DME relay is not engaging.
If there is voltage to both then the DME is getting it's 12 volts along with the injectors (same circuit). Check that the fuel pump is working during cranking. This tells you that the second set of contacts in the DME/fuel pump relay are being pulled in by the DME as it sees the control voltage going to the starter.
You can check wither the DME is reading the flywheel sensor by getting a NOID light and seeing if the injectors are pulsing. No sensor signal no pulsing.
Report your findings.
Old 06-09-2005, 05:40 PM
Also need to check the alarm as this will remove power from the DME too.
Old 06-09-2005, 05:52 PM
