Eldorado's Avatar
what is this rubber hose?
there's a small, approximately a half inch diameter, rubber hose that comes out of the brake fluid resevoir and goes through the drivers side of the hood, and down to behind the front driver's wheel well where it just sticks out there..... what is this hose? can take pics if needed..
Old 06-10-2005, 01:47 PM
SoCal Driver's Avatar
What??? Definitely pictures.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-10-2005, 02:29 PM
Eldorado's Avatar
sure - I'll go take 'em now..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-10-2005, 02:33 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I think you are confusing the blue hose that comes off the reservoir that connects to the master cyclinder ........... and then there is a hose that comes from that area across to the drivers side wheel well for gas fumes into a charcoal reservoir.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-10-2005, 02:37 PM
Eldorado's Avatar
My bad - I obviously didn't look close enough. It actually doesn't come from the brake fluid resevoir... as you'll see from this pic (the white braided line going into the wall)..
first off - what is that?
secondly, here is the rubber hose I was talking about - just behind the drivers side front tire...
Old 06-10-2005, 02:39 PM
Braided (cloth covered) hose is the vent to the charcoal canister that you show in your last picture. Part of the emmissions control system.
Old 06-10-2005, 03:29 PM
AKA J BERK on Rennlist
jsb944's Avatar
If that last pic is of the bottom of the charcoal canister...the hose is a vent hose for the canister I believe.
Joe
Current: 2014 Cayenne S
Gone but missed:
2003 996 C4S; 1991 944 S2; 1984 944 NA
Old 06-11-2005, 03:01 PM
