-   -   DME Relay not the problem... WHAT!?! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/226683-dme-relay-not-problem-what.html)
PhillysMostWntd 06-16-2005 11:13 AM
ok i got my new dme (had the 993 part number, but they are interchangable) put it in, car starts fine, drive it for a few hours, go to work, go to lunch, it works fine, come back, at 10 im coming home, and it doesnt start, i sit and try about 3 times, nothing, so just for the hell of it i put in my almighty 3 legged jumper dme, and it starts fine, i drive home, park it, and put the new dme back in, starts right up. any one have any idea what it might be? im thinking along the lines of a bad fuel pump, or a bad connection, but where is the pump located so i can take a look?
Zero10 06-16-2005 01:35 PM
I would try the jumper for a while, see if the problem re-occurs with the jumper in place. Or, once it starts with the jumper, try popping the relay back in. Perhaps the problem lies within the DME?...
PhillysMostWntd 06-16-2005 01:46 PM
yeah im so confused, ive been driving around for about 2 hours today with the new DME and everything is going fine, dont know whats up
Dave L 06-16-2005 07:12 PM
I asked my mechanic about the DME relays and how long they last. He told me that some times a few years, some times a few hours. It it possible that you purchased a bad relay.
SoCal Driver 06-16-2005 08:25 PM
Check the socket where the relay plugs in. Could be a loose wire or even a bad receiver for the pins on the relay. Your jumper may have oversize pins.
PhillysMostWntd 06-16-2005 09:28 PM
everything has been working fine today (before it got stuck in 4th) but how probable do you think it is that its a bad relay? im not sure what i should do, exchange it or keep it and see what happens
pokey 06-17-2005 05:17 PM
If it does it again, try tapping on the relay with your fingertip. If tat doesn't work, try a twelve pound sledge hammer.
PhillysMostWntd 06-17-2005 07:55 PM
lmao pokey, ill have to try that next time, makes a good saying
"what does not function must be destroyed"
