<insert witty title here>
Christien's Avatar
Starter operation
Please forgive what may be a very stupid question!
I've got an intermittent start problem. When I turn the key I can hear a click from the starter but the car doesn't start. Maybe 25% of the time the car does start.
I pulled the starter out and put it on the bench. I put 12V to it and the plunger thing shot out. Should that plunger thing rotate, or does the conical splined portion force something else to turn?
Thanks!
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 01-07-2008, 12:25 PM
When u energize the solonoid the cog should fly out and engage with ring gear in turn when connected properly the motor starts to turn
if ur getting a clicking noise thats a classic case of nackered solonoid
Are u sure those bits uv labelled arnt a bearing thats come out of the body
Mark
Old 01-07-2008, 01:11 PM
Christien's Avatar
No, I'm not sure. It was last week that I bench tested it, and don't remember exactly.
When I put juice to it, should the cone-shaped piece be rotating?
Old 01-07-2008, 01:22 PM
Learned by do'n twice
Re: starter ops
Assuming you're only putting 12V to the selenoid, it is operating as designed, the selenoid plunger pulls the gear out to engage with the flywheel tooth ring.
Try attaching the 12V to the large lug of the starter where the large wire attaches and then jumper from the large lug to the small lug where the small wire attaches. The starter should them act like you turned the key. The gear should jump out and the starter should turn.
You might try removing the selenoid from the starter, clean up the selenoid plunger and cavity with 220 grit wet/dry sandpaper, and give both a shot of WD-40 before reassembly. Retest before reinstalling, Also, cleanup all wire connectors to the starter and also the battery terminals.
jmd_forest
Old 01-07-2008, 01:25 PM
Proprietoristicly Refined
John_AZ's Avatar
Here is a starter rebuilding site to give you a better view and has tips.
http://forums.vwvortex.com/zerothread?id=2359900&postid=42115781
John_AZ
1988 924S + 1987 924S
Old 01-07-2008, 02:04 PM
Christien's Avatar
Alright, thanks everyone. From your responses here, that site with the rebuild instructions and a couple youtube videos, I've determined I need to just replace the bugger. For $40 or $50 I'd rather do that than try to rebuild it.
Thanks!
Old 01-07-2008, 03:51 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
A click can also mean you aren't getting a full 12V to the starter. This could be a battery cable or bad connection at the starter. Check your voltage at the end of the battery cable that goes on the main post. Of course as mentioned it could be the solenoid.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-07-2008, 08:22 PM
Send a message via AIM to Lapponia
Interesting! Bushing stuck on the axle end (pulled out earlier?) . Solenoid cant move its hole way and no amps will get to the armature and therefore no rotation - just clicking with a little movement from the solenoid and cog. Could it be so?
Lapponia 84 - 944 N/A (man).
Old 01-09-2008, 07:00 AM
