shift boot support frame help
On my 83 porsche 944 i have a new shift boot support frame, but it wont seem to stay in place. It has 4 clips on corners that should snap into place on the console but it never seems to stay on. Is there a technique to keep it on, or should i just cut the clips off and glue the piece down? Thanks.
Old 08-07-2005, 11:04 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
mine dances around also. Part of the problem for me was that the inner boot rubber piece was torn and pushing against that frame in weird ways. hard to describe. Another part of my problem was that the linkage needed adjusting, so my throw was too far and it was making the whole boot piece move.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 08-07-2005, 11:24 AM
SoCal Driver's Avatar
I drilled each corner into the tunnel sheetmetal and screwed it down. Been wanting to make an aluminum replacement.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-07-2005, 06:16 PM
