Question auto tranny problem
does anyone know if you can bypass or jump out the neutral
start or safety switch. sometimes it does not know if it is in
park or neutral and will not start. i can shift it between park
and neutral a few times and then it will start.1986 944
Old 06-26-2005, 06:31 PM
gear selector 'interlock' switch has a pair of red/black wires that must connect to each other (through the switch) to supply 12 volts to the starter.
interlock switch is mounted to the gear selector bracket.
Tom
Early '85 944
Old 06-27-2005, 06:11 PM
livewirevoodoo's Avatar
damn... just posted about that here: Weird Non-Start Condition (automatic)
well, atleast I think it is about the same thing. and i think carson just answered my question...
gear selector interlock switch, ehhh?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 06-27-2005, 06:18 PM
Thumbs up
thanx for the info carsontc the contacts on the switch are worn out new one is on the way from porsche
Old 07-04-2005, 11:01 AM
